Rob D Posted Wednesday at 09:22 Report Posted Wednesday at 09:22 Hi, It's my first post there so hi everyone! I'm wondering if this door is repairable or needs replacing due to the holes in the door behind the push pad? https://ibb.co/S4v3fSbr https://ibb.co/DDNwq4t7 Otherwise the door is in good condition. Thank you Rob Quote
AnthonyB Posted 12 hours ago Report Posted 12 hours ago If that is a final exit to the outside then there is every likelihood it doesn't need to be a fire resisting door so you can simply fill the holes with whatever you want to prevent draughts. Quote
