Guest Jos Oliver Posted Friday at 09:00 Report Posted Friday at 09:00 Can I replace the i240C with a four-wire rechargeable battery model, don't know. anyone help? Quote
green-foam Posted 14 hours ago Report Posted 14 hours ago Probably not. It depends what make/model of smoke alarm you currently have (i240c?) and more to the point what do you want to replace it with and are there any more smoke alarms? You can not "mix and match" brands of smoke alarm if they are interlinked, but all good smoke alarms should be interlinked. Also unless it has a 10 year battery, I would never suggest changing a mains smoke alarm for a battery smoke alarm. Quote
