December 18, 20232 yr comment_40124 Hi team, Thanks for your help. I have the Ei141RC Aico smoke alarm - wired with 9V battery backup I have 10 of them through my property - all connected on one circuit The green lights are constantly on for all of them meaning mains power seems stable I have recently replaced all batteries with 9V Duracell's and held down reset test button for 10 seconds after installing to reset I have two issues 1. The red light should be flashing every minute but on the downstairs one they flash every 1 second and the upstairs one they are blinking constantly / multiple times per second. It's distracting when trying to sleep. 2. The 4 alarms on our top floor will start beeping randomly. They beep every second for 10-20 seconds then stop. Then start again a few minutes later. Would love your help diagnosing and fixing Rob Report
December 18, 20232 yr comment_40136 Hi, the aico Ei141RC is an ionisation smoke alarm and is obsolete, I would suggest that the "symptoms" you mention are an indication of end of useful life. The direct replacement is the Aico Ei146e Click me Report
