Fire alarm kac conventional mcp
Why is the KAC manual call point not working on a c tec conventional panel.
The panel Is ending in 04 this is a cfp panel
Have you wired it right? Have you installed the EOL capacitor, have you the correct KAC MCP? Have you swapped its position with an existing MCP?
I can't be more specific as you gave so little information.
