July 30, 20232 yr comment_37757 Hi, I am thinking to fit something like surface mounted intumescent strips or surface mounted intumescent fire & fire/smoke seals over the hinges and the latch area, because I don't understand how smoke wouldn't pass through those. I wanted to get your expert opinion: is it a good idea? Bad idea? Useless? Report
July 31, 20232 yr comment_37780 There are better ideas: For FD30 doors the intumescent seal may be interrupted at the hinge positions (3 @ 100mm) and single lock/keep. For FD60 one of the twin the intumescent seals can be located to by-pass hinges due to the extra thickness door leaf. For smoke sealing use a seal that is attached to the door frame rebate stop, therefore continuous without interruption. Report
August 1, 20232 yr Author comment_37799 Thank you @Neil Ashdown MAFDI, do you mean something like this? https://envirograf.com/product/surface-mounted-brush-smoke-seals/ I can look into it, I understand how you would fit it at the hinges side, but how would you install it on the latch side? I also understand that this is a better solution based on your expert advice, but if I installed something like Surface mounted intumescent fire & fire/smoke seals at the hinges and latch, would it be better than nothing? https://envirograf.com/product/surface-mounted-intumescent-fire-firesmoke-seals/ Report
August 2, 20232 yr Author comment_37824 thank you, I will have to understand how to fit those but thanks Report
August 3, 20232 yr comment_37845 These fit to the door frame rebate stop so that the flexible seal compresses when the door leaf closes against the stop. Report
