June 22, 20233 yr comment_37074 Hi All Can an escape route go through different purpose groups to get to a final exit? I.e.. From Purpose group 3 (Office) to 4 (Factories) then to final exit. Thanks Report
June 26, 20232 yr comment_37114 A couple of q's: - Are they different fire compartments? - Are they part of the same occupancy? Report
June 27, 20232 yr Author comment_37156 Hi Anthony Yes they are separated fire compartments. Yes the occupancy is the same. Thanks Report
June 28, 20232 yr comment_37174 In theory yes if required, the travel into an adjoining compartment helps reset the travel distance clock as well similar to reaching a storey exit. Report
