August 13, 201213 yr comment_2356 I need to install a fire door in my extension. Can my builder do this or do I need a registered joiner? Harry Report
August 13, 201213 yr comment_2357 Hi Harry Although a competent builder or joiner can install a fire door, I would recommend that the work is carried out under the auspices of the Accredited Fire Door Installers Scheme. This scheme has been developed by the British Woodworking Federation (BWF) in association with FIRAS, with the purpose of ensuring that fire door installations are carried out correctly, safely and in compliance with current Building Regulations. Once the fire door has been installed, it is also important that you carry out regular maintenance checks to ensure that it remains fit for purpose. Ask the installer for guidance on the issues to look for. If you choose to keep the door open with a fire door retainer, close the door at night to avoid warping of the door. The Dorgard fire dorr retainer, for example, has a night time release. Harry Report
