June 30, 20223 yr comment_27435 Does anyone know if the requirement for LD2 and LD3 in converted flats has changed or still the same as that stated in the LACoRS guidance? Report
July 1, 20223 yr comment_27477 The mixed system as per LACORS is still appropriate, just allowing for the changes in the newer BS5839-6. LACORS is under review as it needs refreshing, but this seems to have stalled. Report
July 1, 20223 yr comment_27479 1 hour ago, AnthonyB said: Thanks Anthony for clarification The mixed system as per LACORS is still appropriate, just allowing for the changes in the newer BS5839-6. LACORS is under review as it needs refreshing, but this seems to have stalled. Report
