Guest Mol1 Posted February 17, 2022 Report Share Posted February 17, 2022 I have previously installed interlinked smoke alarms in 2005 (not wireless) i now need to add a heat alarm to comply with regulations can I do this with my existing set up or do I have to change all my alarms to wireless? Thanks Quote Link to comment Share on other sites More sharing options...
green-foam Posted February 21, 2022 Report Share Posted February 21, 2022 If you installed wired smoke alarms in 2005 You should change ALL of them as they only have a 10 year life. If it is easy to install a new 3 core and earth cable from one detector to your new Heat alarm, then I would do that as it will be cheaper than all new radio alarms, but if it is not easy then yes, change them all to radio interlinked alarms. Quote Link to comment Share on other sites More sharing options...
