August 21, 20187 yr comment_12502 Hi, My management company is asking me for a certification that my front door is a 30 or 60 min fire door. The only certificate I have is a Fensa ceritificate. Does it also certify that I have the required doors installed? Thanks for the info in advance Report
August 22, 20187 yr comment_12504 Usually, the management company will require evidence that your flat entrance door is fire resisting to the BS 476 part 22 or BS EN 1634-1 fire performance tests. Therefore, if the FENSA certificate does not provide such evidence then they will not accept it. If you do not have the required evidence a Certificated Fire Door Inspector could help by inspecting the door and providing a report to confirm whether or not the door is suitable as a fire resisting flat entrance door http://www.fdis.co.uk/inspector Report
