October 4, 201510 yr comment_8003 I was wondering if you have any idea's on the following.My son who has a severe hearing loss has recently moved into new digs (block of flats), the integral fire alarm system is only up to 65dbs, the deafguard that has served him well up till now reacts at anything over 75db, so not much help here.Do you know if anything is out there that will vibrate/flash etc at 65db. When the flat fire alarm goes off.I have looked but not found much yet Report
October 4, 201510 yr comment_8005 Hi Lesley, the Deafgard can be adjusted http://www.safelincs.co.uk/templates_safelincs/files/datasheets/216_Deafgard user guide.pdf This might help Harry Edited October 5, 201510 yr by Safelincs error Report
