Companies to change Internal Fire Doors to Outward Fire Door
Hello
I'm looking for advice on companies who could quote to complete work to install new external facing fire doors. Currently we have two doors that open inwards thus capping capacity to 60.
We are applying for capital and would appreciate any guidance on who to contact. We are in East Midlands if that narrows things down,
D
Do you need fire rated doors?  There are only specific cases where a final exit door needs to be fire rated.
1.      Communal escape routes Flat entrance doors opening onto shared hallways or stairwells in multi‑occupancy buildings must be fire‑resisting.
2.      Boundary proximity External doors in walls very close to a neighbouring property line may need a fire rating to prevent fire spread between buildings.
3.      Commercial / high‑risk areas External doors forming part of a fire compartment line in commercial premises, industrial units, plant rooms, or bin stores may require FD30/FD60 protection.
4.      Integral garages the internal door between a dwelling and an attached garage often needs to be fire‑rated, though standard external exit doors do no
If they are needed, do a google search for fire door installers near me, then you will need to do your due-diligence to select the installer, if not then any decent chippy can change the doors to swing in the opposite direction
