June 16Jun 16 comment_55968 Hi all.I'm looking for some advice.Recently completed an FRA on a small/medium commercial unit. All pretty straight forward, however, there are building works going on next to the unit -looks like a new unit is being erected.I noticed that when you open the toilet window in my customers unit, it opens directly into the building site next door The building work is nothing to do with my customer (they lease their unit). Obviously, I know this is an issue and the building site activities can affect my customers' unit and vice versa, but is there anything else I need to consider? Any other guidance/legislation. I'm certain this wouldn't meet building regs, but nothing I can do about that. This is the first time I've ever come across this so I'm a bit stumped.The building site was closed when I was there so it wasn't possible to talk to any of the contractors.Any advice will be very much appreciated.Happy to answer any questions.Thanks in advance. Report
June 18Jun 18 comment_55973 Is the window an escape window, does it comply with ADB para 3.6?If yes then can the fencing be moved to create and escape corridor?Once the works are completed, will the new works continue to cause a problem? Report
June 18Jun 18 Author comment_55976 6 hours ago, Mike North said:Is the window an escape window, does it comply with ADB para 3.6?If yes then can the fencing be moved to create and escape corridor?Once the works are completed, will the new works continue to cause a problem?Hi, Mike. No, the window is not an escape window and the building wasn't built to ADB. I should clarify that the window opens INSIDE the new unit, not externally. So when the building is finished, it looks as though the toilet window will open inside the building (what part of the building it will be, I don't know). So I would say that it's likely this will remain a problem (probably more so) when the unit is finished. Report
June 22Jun 22 comment_55978 Without looking at it myselfThis could go from.If the new unit is under the same occupant as the original, then as long as there is no fire load, I would note it and class it as tolerable.ToIf they aren’t under the same occupancy, the window should be rated as FD60 (as a minimum)You need to look at Part G Sanitation, hot water safety and water efficiency Report
