June 11Jun 11 comment_55958 Hello there I do hope someone can advise meI am a private tenant in England renting a 2-storey residential family house. it has 4 bedrooms and it was converted from a commercial pub to a residential dwelling and I am deeply concerned about the fire safety and escape layout upstairs and want to confirm if this constitutes a serious hazard.Here are the specific details of the property:The Corridor: The upstairs hallway is a 7.58 metre long corridor. There are no windows, exits, or alternative escape routes at the back of the property. The only way out is down a single staircase in the middle, the width of the corridor warps and is 84cm, 88cm, 91cm, and 93cm in widthThe Internal Doors: All bedroom doors leading along this 7.5m dead-end corridor are basic, standard timber doors and they have visible structural gaps at both the tops and bottoms.The Windows: All 4 upstairs bedrooms have windows, but they are fitted with restrictive top and bottom dual safety catches. They meet physical opening sizes but are incredibly difficult and slow to operate in a rush or panic.Given it exceeds 7.5m length, the doors have no smoke seals, no windows out the back or exit and the emergency escape windows are difficult, is this likely to fail UK Building Regulations?Many thanksJames Report
June 16Jun 16 comment_55967 If the windows comply with ADB para 2.10, there is no requirement on a 2-story dwelling house for a protected escape route, therefore the doors don’t need to be fire doors. It would only be an issue if there were another floor.For a dwelling house, the maximum travel distance 18m from the furthest point in a bedroom to a protected exit or place of safety.You may need something doing to the window restrictors Report
July 4Jul 4 comment_56006 The single most important thing you should do is to ensure that there is adequate early warning fire detection installed. As a minimum this should be installed on an LD2 basis (heat detector in the kitchen interconnected to smoke detectors in the corridor). The smoke detectors should be loud enough to wake sleeping occupants and you should test these on a monthly basis. If you are concerned that they are not loud enough or have other concerns, you could upgrade them to have LD1 coverage (interlinked detectors in all rooms). The other thing you should do is to ensure that your escape route from the furthest point in the house to the final escape door is kept clear at all times. Report
