Guest Tony Posted April 25, 2025 Report Posted April 25, 2025 We have a couple of door sets in our building that I think are not compliant but would like to know if they can repaired. The first doorset had the door opening into the room but got turned around to open outwards. The frame now has an intumescent/smoke seal on the frame with the brush removed and painted over and the seals has now been put in the door. Should this be left or removed?. What is a repair technique for this? The second doorset it looks as though someone has planed it slightly. Would this cause an issue with the frame ? Thank you in advance. Quote
