March 11, 20251 yr comment_48016 I have a block of elderly steel fire doors mounted on two swivel hinges top and threshold. (They do not swivel two ways.) No stopper. Smoke seals. The threshold gaps are in excess of 9mm. Is there anything on the market or drop down seals that would make the doors compliant? With no stopper, conventional drop seals couldn't be activated. Any thoughts pls. Report
March 13, 20251 yr comment_48086 It depends on the condition of the floor. You could fit a static flexible seal to one face of the door leaf to seal the bottom edge but the seal must not impede the self-closing action of the door. Report
