Guest Jay Posted February 20, 2025 Report Posted February 20, 2025 Hi, I normally use D4 or PVA to attach lipping to a FD30. To spead up the prosess can I use glue then nail gun it instead of using clamps? Quote
Neil Ashdown MAFDI Posted February 24, 2025 Report Posted February 24, 2025 If using pins be careful to avoid ironmongery fitting positions and bury them as deeply as possible. Make sure the adhesive you use matches the requirements of the evidence of performance (field of application report) for the door leaf / door blank / door core. Quote
