January 29, 20251 yr comment_46940 Fire Hinges. Do they need to be marked grade 13 or is FD30 CE marked hinges acceptable? Report
February 3, 20251 yr comment_47030 The recommendation is that hinges for fire doors are minimum Grade 11 to BS EN 1935. Most certificated fire doors require that hinges are CE or UKCA marked in accordance with that Standard. Details in the guidance document Code of Practice: Hardware for Fire & Escape Doors. https://www.firecode.org.uk/ Edited February 3, 20251 yr by Neil Ashdown MAFDI To correct a typo Report
