Friday at 06:193 days comment_56304 Hi all,I’m looking for some technical advice on the best approach to achieving 30 minutes’ fire resistance to an existing timber ceiling within an older Cornish cottage.As you can see from the attached photograph, the ceiling consists of substantial exposed timber beams, smaller intermediate joists and timber floorboards above.Ideally, we’d like to retain the exposed beams if possible, although fully boarding over the ceiling is also an option.I’m particularly interested in whether there are any suitable tested systems that would allow fire-resistant boarding between the beams, potentially combined with intumescent protection to the exposed timber.I’m conscious that any proposed solution needs to be supported by appropriate test evidence and be suitable for the existing construction.Has anyone encountered a similar situation or successfully used a particular manufacturer’s system? Alternatively, would a project-specific assessment by a fire engineer be the most appropriate route?Any advice or recommendations would be much appreciated.Thanks in advance. Report
