April 22, 200917 yr comment_36 Hi Folks I use a Deafguard smoke alarm (purchase proof attached) which is displaying an Error 2 when I test the alarm. Unfortunately I do not have the instructions to hand. Can you please advise the corrective action for this, if any? If it needs servicing can I bring it in? I live in Lincoln. Many Thanks D.G Report
April 22, 200917 yr comment_37 Dera D.G It should be sufficient to take out the batteries, ensure that the pillow pad is inserted and then re-insert the batteries Kind Regards Garry Report
