Guest Andrew Russ Posted January 23, 2019 Report Share Posted January 23, 2019 Fitting Intumecent Air Vents into a half hour fire door. Since the grenfeld incident has there been a change regarding the fitting of vents into fire doors, a supplier is telling us that we cannot now fit ??? It fir the top open air floor of a multi story car park. Any assistance would be appreciated. Quote Link to post Share on other sites
Tom Sutton 0 Posted January 23, 2019 Report Share Posted January 23, 2019 It all depends on the type of fire door, if it is a FD30 fire door then it could be acceptable, if it is a FD30s fire door which is designed to control cold smoke then it is a no no and you would need to fit an active device that would control the passage of cold smoke and hot gases/fire. Quote Link to post Share on other sites
daveol 0 Posted May 26, 2019 Report Share Posted May 26, 2019 regs state now these have to be fitted when purchasing a fire door from manufacturers of if you have approval from the manufacturer to fit these, somehow I think they wont give you it but will supply you with it already fitted to your building fire assessors specs. Quote Link to post Share on other sites
Tom Sutton 0 Posted May 30, 2019 Report Share Posted May 30, 2019 daveol could you please quote the regs you speak of I need to add it to my database. Thanks. Quote Link to post Share on other sites
daveol 0 Posted May 30, 2019 Report Share Posted May 30, 2019 tom its not hard to find out. ive just completed fire door fitting and maint courses and inspectors course at BRE. you should not cut any apertures into doors for glazing or vents unless you are approved by the manufacturer. if you fit it from a blank you wont have any certification as it will not have been tested to destruction, no certification = non compliance with building regs Quote Link to post Share on other sites
Tom Sutton 0 Posted June 2, 2019 Report Share Posted June 2, 2019 I disagree if you fit a blank and construct it in accordance with the global assessment that should come with the door it is very likely to be accepted by building control as a nominal fire door. However, I do agree you need the appropriate training and if a door cannot achieve the minimum standards of the appropriate guidance then it should be upgraded to the latest standard. Quote Link to post Share on other sites
daveol 0 Posted June 6, 2019 Report Share Posted June 6, 2019 yes you could fit a blank to the correct standards, but you then have no certification for it as it will never have been certified under test conditions. therefore it will be a non compliant door as it does not have a certificate. Quote Link to post Share on other sites
Tom Sutton 0 Posted June 9, 2019 Report Share Posted June 9, 2019 No it would be a nonminal fire door which there are many out there and can be acceptable to many BCO/AI,s, in fact at the end of the global assessment there is a document thats makes this point. Quote Link to post Share on other sites
Guest Ian Robertson. Posted May 24, 2020 Report Share Posted May 24, 2020 On 09/06/2019 at 18:02, Tom Sutton said: No it would be a nonminal fire door which there are many out there and can be acceptable to many BCO/AI,s, in fact at the end of the global assessment there is a document thats makes this point. I agree with you on this Tom. The case Daveol makes then every notional / nominal fire door assembly would be non compliant as it has not been tested as a complete unit and certified. Quote Link to post Share on other sites
green-foam 0 Posted May 26, 2020 Report Share Posted May 26, 2020 Ian, daveol is unlikely to reply / defend his comment as it was made Last year, and it was daveol's last post. 🤐 Quote Link to post Share on other sites
Guest RhodesWorksPP Posted January 23 Report Share Posted January 23 Hi all, quick question on vents if I could please? I've been asked to upgrade a vented FD30 door set, to a FD60s (controlling cold smoke), but have been advised it still requires a vent? I'm not challenging Building Control, or the Architect and will install as requested, I'm just wanting to understand why you would put a vent in a door, where you are installing smoke seals. Thank you Quote Link to post Share on other sites
AnthonyB 0 Posted January 24 Report Share Posted January 24 What ever is in the room needs good ventilation during normal situations, hence the vent, but in the event of a fire needs to be sealed. Requesting a vent in a door requiring smoke sealing becomes more complex as a standard intumescent vent won't suffice and it needs to be a fire & smoke damper activated by the fire alarm system:https://www.lorientuk.com/products/air-transfer-grilles/fire-smoke-damper Quote Link to post Share on other sites
