Guest PaulKeeg Posted March 17, 2012 Report Share Posted March 17, 2012 Morning Our smoke alarm started bleeping last night and kept the dog awake! When i checked this morning i could not change the battery. Its connected to mains and its a kidde firex. Anybody can help? Paul Quote Link to comment Share on other sites More sharing options...
Safelincs Posted March 17, 2012 Report Share Posted March 17, 2012 hi Paul, you are lucky we are in the office :) There is a range of simple videos to see how the Kidde Firex smoke alarms can be taken of the wall and how the battery is changed. How to replace the backup battery in a Kidde 4973 optical smoke alarm Replacing the backup battery in a Kidde ionisation smoke alarm 4870 How to replace the backup battery in a Kidde 4899 heat alarm I hope this helps Harry Quote Link to comment Share on other sites More sharing options...
Guest Posted August 27, 2015 Report Share Posted August 27, 2015 thanks for this...I never knew there was a back-up battery Quote Link to comment Share on other sites More sharing options...
Guest Mike Posted December 30, 2016 Report Share Posted December 30, 2016 Wont be buying alarms like this taking the wires off is nearly impossible no need to make this so complicated Quote Link to comment Share on other sites More sharing options...
green-foam Posted December 30, 2016 Report Share Posted December 30, 2016 Using a plug to connect to a smoke detector is not only easier than terminals, it is safer and ensures that the detector is connected correctly when reconnected / replaced. I don't find removing a plug "complicated" Quote Link to comment Share on other sites More sharing options...
Guest Annie Posted April 14, 2017 Report Share Posted April 14, 2017 My alarm started beeping. I changed the battery according to your video and it is still beeping. What next? Quote Link to comment Share on other sites More sharing options...
Safelincs Posted April 17, 2017 Report Share Posted April 17, 2017 Hi Annie I suggest two steps: 1) check the replacement date for the alarm. All mains powered smoke alarms should be replaced after ten years as they can become erratic. 2) make sure there is not a carbon monoxide alarm nearby that has a low charge battery and therefore beeps. These beeps can be very deceiving. To find out, take your Kidde alarm off the ceiling, remove the battery, press the hush button to drain any charge left and listen out for a few minutes. If this leads to nothing, you will have to replace your alarm. Here a list of Kidde replacement smoke alarms Harry Quote Link to comment Share on other sites More sharing options...
Guest David Posted January 9, 2019 Report Share Posted January 9, 2019 Hi I have been in a New build for just over two years and have a Kidde 4MCO alarm. It was installed in late 2016 and has just started beeping every 60 seconds. From what I am reading it sounds as if the battery is at end of life, but isn't replaceable. Is that correct and, if so, should it be covered under the warranty? Quote Link to comment Share on other sites More sharing options...
Safelincs Posted January 9, 2019 Report Share Posted January 9, 2019 Hi, yes, this Kidde CO alarm has a six year warranty. However, you need to make sure that the power supply to the CO alarm is actually working, otherwise the alarm will indeed drain and start beeping. Harry Quote Link to comment Share on other sites More sharing options...
Guest Bumps Posted July 21, 2019 Report Share Posted July 21, 2019 I have tried and tried to get the power plug out of a 1240C and I can not budge it, I have even tried to prise it up with a screw driver! What is the correct way to do this? I am trying to replace it as it is over 10 years old. Thanks in anticipation Quote Link to comment Share on other sites More sharing options...
Safelincs Posted July 22, 2019 Report Share Posted July 22, 2019 Hi, the closest instruction video for a removal of a Kidde Firex smoke alarm is here Harry Quote Link to comment Share on other sites More sharing options...
Guest Jessica Posted October 25, 2019 Report Share Posted October 25, 2019 On 21/07/2019 at 12:01, Guest Bumps said: I have tried and tried to get the power plug out of a 1240C and I can not budge it, I have even tried to prise it up with a screw driver! What is the correct way to do this? I am trying to replace it as it is over 10 years old. Thanks in anticipation Hi I’m having the same problem! In the Video it looks like he is squeezing something but there isn’t anything to squeeze!! Did you figure it out? Quote Link to comment Share on other sites More sharing options...
Tom Sutton Posted November 1, 2019 Report Share Posted November 1, 2019 I would suggest you contact the manufacturer to find out, but it could be more serious like the pins have oxidized and there would be no way of removing the smoke alarm other than removing the wiring and fitting a new base plate with smoke alarm. Quote Link to comment Share on other sites More sharing options...
Guest Jim Posted May 11, 2020 Report Share Posted May 11, 2020 I am trying to replace the battery in the Kidde Firex KF1 smoke alarm and cannot get access to the battery compartment as the cables are almost impossible to remove any help! Quote Link to comment Share on other sites More sharing options...
Guest Jim Posted May 11, 2020 Report Share Posted May 11, 2020 looks like the tab needs to be lifted with a flat screwdriver, until the battery door can be opened Quote Link to comment Share on other sites More sharing options...
Tom Sutton Posted May 16, 2020 Report Share Posted May 16, 2020 Check out https://www.bing.com/videos/search?q=changing+battery+in+Kidde+Firex+KF10&qpvt=changing+battery+in+Kidde+Firex+KF10&FORM=VDRE Quote Link to comment Share on other sites More sharing options...
Guest Maciej Posted July 30, 2021 Report Share Posted July 30, 2021 Hi my carbon monoxide alarm(4mco) beeping show low battery its 3 day since I instal Quote Link to comment Share on other sites More sharing options...
green-foam Posted July 30, 2021 Report Share Posted July 30, 2021 If it says low battery then have you tried changing the battery? It may be the device has an old battery from new. Quote Link to comment Share on other sites More sharing options...
Guest Kidde Smoke alarm Posted August 5, 2021 Report Share Posted August 5, 2021 i have one and despite instructions to insert a flat blade screwdriver and pull cover - no it doesn't work - bleeping for 4 hours now and can't get cover off - not designed for old fingers that's for sure Quote Link to comment Share on other sites More sharing options...
Harry Posted August 8, 2021 Report Share Posted August 8, 2021 Hi There is a help video about how to remove the Firex/Kidde alarms which should apply Harry Quote Link to comment Share on other sites More sharing options...
